JIRA plugin upload issue
nidhi sharma August 16, 2015
Hi Team,
I am using JIRA cloud.
I have tried installing new plugin to my JIRA,
but in "Upload add-on" tab it is showing option to enter URL from where plugin can be downloaded but it is not showing option to browse and download it from your machine.
It used to come earlier.
Please suggest.
Nidhi
nidhi sharma August 17, 2015
I am not sure what is meant by Type of add-ons,
This add on is used for securing custom fields permissions.
Link for reference: https://marketplace.atlassian.com/plugins/com.coresoftlabs.secure-fields.secure-fields
Can you please let me know how to get its type?
The problem is for any plugin it is just showing to upload its URL, It is not asking to upload downloaded plugin file. Please find attached screenshot.                        upload add-on.png
Jay Cosgrove
October 9, 2018
Having a similar issue. Any update on this @nidhi sharma or @Nic Brough -Adaptavist-?
October 9, 2018
It's the same answer - you can't load "type 2" add-ons into Cloud.
August 16, 2015
You can't upload type-2 addons into Cloud.  You can load Connect addons, but you have to go via the marketplace to do that.  What type of addon have you written?
I am trying to upload ":Secure Fields for JIRA" ad-on.
It is asking to upload it using URL.It is not showing option to browse and upload
August 16, 2015
That doesn't tell us what type of addon it is. Also, you've said "cloud" which doesn't even have the "upload" option. You need to be clear on what you are trying to do here.
In Cloud there is a "setting" option adjacent to "Audit log" button/.
Where we can enable its private listing checkbox.
Once we do it, in "Find new add-on" section It shows "Upload add-on" button adjacent to "Build add-on".
There I am trying to upload a add-on provided by Atlasian.
August 16, 2015
Thanks for clarifying, that makes a lot more sense to me. So, the question again becomes what type of addon is it?
