JJupin - Live Fields: How to know the issuetype in a SIL script?
Begoña Bonet
I need to launch a lfSet("customfield_XXXX",{" "," "}) in the initial script only when user launches specific transitions in flows.
The next code doesn't works for me:
string pantalla=argv["screen"];
if (pantalla == "trans_841")){
     lfSet("customfield_20901",{" "," "});
becasue the transition 841 exists for several flows and are diferents transitions.
Then, my problem is: the same "transition id" has been assigned to diferent transitions in several flows. Then I need to distiguish in which flow is the user when the transition is launched. For example, I need to know the name of the flow or the issuetype (because I've a distinct flow for each issuetype).
How can I do that?
Alexandra Topoloaga
February 11, 2016
You could try something like this:
if (pantalla == "trans_841" && issueType == "Bug")){
or you could try to simply add a postfunction on that transition in which you set the value:
customfield_20901 = {" ", " "};
Hope this helps,
Alexandra
Begoña Bonet
I'll try with the firts option because I need that the customfield was cleaned when the transition screen opens. After that the user can populate the customfield and I can't clear this value.
Learn more
