JMWE Condition to check if users in a multi-user picker are in a certain group
Tom Hudgins
I'm trying to write a JMWE post-op transition script that will conditionally transition the issue only if ALL the users in a multi-user picker are in a certain group.
I have this:
{% for user in issue.fields.customfield_19486 %}
{{ user | isInGroup('training-complete') }}
{% endfor %}
and I get something like
true
false
but what I really want is just a true/false for the entire set of users overall.
I feel like I should be able to use a filter that looks something like this:
{{ issue.fields.customfield_19486 | filter({isInGroup('training-complete')}) }}
I know that's not the syntax for a filter but I can't quite figure out how to do this more succinctly.
Thanks for any help
David Fischer
Hi @Tom Hudgins
try this:
{% set allIn = true %}
{% set allIn = allIn and (user | isInGroup('training-complete')) %}
{% endfor %}
{{allIn}}
Tom Hudgins
Thanks David,
I had toyed with going down this route but it felt like there might have been some sort of one-liner that would do it.
In the end, I have to add more logic for a few other tests so this is better anyway - and more readable as well.
Thanks very much!
Russell Kent
October 31, 2024
@Tom Hudgins Did you ever figure this out? I'm interested in a solution if you wouldn't mind sharing some of the code.
Tom Hudgins
I used basically the same code as proposed by David. I ended up setting the original value to false and then OR'ing the "inGroup" response inside the loop but it's basically the same thing.
Like • Russell Kent likes this
Shawn Doyle - ReleaseTEAM
Change the code to exit after the first False.  If there isn't any False then the code will return True.
