[JMWE] Current user Validator (please Help)
RIZKY JTUASIKAL
There is a condition, where I am the current user, and registered in the User* field.
and I want the following conditions to work, ie:
if I am registered in the User* field, then the User Evidence Url field must be left blank.
how can the above condition be achieved?
because I used the following method, and the condition could not be achieved.
3 accepted
4 votes
Neel Mohapatra _Appfire_
April 22, 2024
Hi @RIZKY JTUASIKAL ,
You can make use of a validator like the one shown below and add a condition checking if the current user matches the User field and then check if the field is empty.
Let me know if you have any questions or if it helped.
RIZKY JTUASIKAL
Hi @Neel Mohapatra _Appfire_ ,
I tried using your advice, and it worked!!!
thank you very much for your help, and have a good day
Rizky
Like • Neel Mohapatra _Appfire_ likes this
David Fischer
Hi @RIZKY JTUASIKAL
You cannot achieve this with the User validator. You need to use a Build-your-own validator with a script like:
user.accountId != issue.customfield_12345?.accountId || !issue.customfield_12905
 where you need to replace customfield_12345 with the field ID of the User* field
RIZKY JTUASIKAL
Hi @David Fischer ,
I thought I could use User Validator to get those results :(
thank you so much for your advice, it means a lot to me!
Vikrant Yadav
Hi @RIZKY JTUASIKAL In such case, you need to create a post function, if User* = currentUser then clear field "User Evidence Url"
Or with the help of automation you can also do this, set field value to null if User* = currentUser.
John Funk
Hi Rizky,
I am not a JMWE expert but it looks like you need to add a condition also to check if the field is Empty (null). So it would be an OR.
Learn more
