JMWE Validator Condition
Yoann LEGRAND
Hi Team,
I have a use case , I cannot find to create a good validator with JMWE in Jira Cloud on Create transition.
I would like to allow ours users to create an issue only on specifics combinaisons of a CF(Select list) and Components.
I use JMWE with this validators : "Build-your-own Validator"
CF_AComponentResult condition
select listAB
000True
001True
010True
011True
100True
101False
110False
111False
(My Validator is on field issue Type :  if issueType = Bug => block ...and we are on Bugs's Workflow.
So if condition return True => Block , if condition return false, we skip the validator and user can create the issue)
So for exemple:
If my Selectlist  = "0" and I have component = "A" , my condition return "True"
So my Validator block the creation
If my Selectlist  = "1" and I have component = "B" , my condition return "False"
So my Conditional validation skip the validator and the creation is allow
I try this for my conditional Validation :
(issue.customfield_10054.value == "1" && (issue.components.some(it => it.name != "A"))) || (issue.customfield_10054.value == "1" && (issue.components.some(it => it.name != "B")))
But It's not ok, still return "True"
I think because we are still one or other option  .. True.
We cannot use if/else in Validator condition ( only in postfunction) right ?
So I don't know how to do this , any help are appreciate :)
2 accepted
David Fischer
May 6, 2024
Hi @Yoann LEGRAND
A simpler version of the Jira expression:
issue.customfield_10054.value != "1" || !issue.components.some(it => it.name == "A" || it.name == "B")
 which will pass if the custom field value is not "1" or if the component doesn't contain A or B
Yoann LEGRAND
Thx David :)
Yoann LEGRAND
OK, I've found it ! I post answer here , if some people block like me ;)
(issue.customfield_10054.value == "1" && (issue.components.some(it => it.name == "A"))) || (issue.customfield_10054.value == "1" && (issue.components.some(it => it.name == "B"))) || issue.customfield_10054.value != "1"
But not in "Conditionnal validation" .. directly in Jira Expression !
It easy in fact ... I'm looking for too complex !
