JQL Σ Remaining Estimate
Erik Gotera September 10, 2018
I am looking the way to search by Σ remaining estimate, because we make the estimation in the subtasks and we want to get the result of the following search in the parent issues:
Σ remaining estimate > 1d
Is possible?
Nic Brough -Adaptavist-
September 10, 2018
I'm afraid you can't do this natively.  Jira does not expose the  fields in search.  You'll need an add-on that provides a JQL function to do it (I've not seen one myself, but I'd use ScriptRunner to create one if I needed it.  Only because I've got SR experts on hand)
Reg Hawkins September 19, 2019
https://jira.atlassian.com/browse/JRASERVER-69914
https://jira.atlassian.com/browse/JRACLOUD-25057
We have 2 suggestions outstanding relating to subtasks and I think as part of the requests the functionality you mention could be added
Annie Charbonneau June 27, 2019
Hi Erik,
Same issue here! Would love to see a solution for this.
Thanks in advance!
Anna Bogdanova
January 15, 2019
Hi Erik!
I faced to the same case, have you found solution to get Σ remaining estimate?
Thanks in advance!
Milan Chheda [INFOSYSTA]
September 10, 2018
Did you try:
remainingEstimate is NOT NULL
Mohamed Benziane
Hi Erik,
If you have Scriptrunner you can try two function on your jql query:
hasSubtasks()
or
issueFunction()
Regards
Hope this helps
Erik Gotera September 10, 2018 edited
Hi Mohamed,
Thanks for the reply but I don't understand what you try to say me with that.
In the JIRA search, you can add a field call Σ remaining estimate where you can see in the parent issue the total remaining estimate of all the subtask.
I want to be able to make a query looking for that field.
Is possible? How?
Thanks!!!
Mohamed Benziane
HI,
Sorry for the misunderstood, can you try this
remainingEstimate>1d
 Regards
That is not working, because remainingEstimate is set when I log a work in the parent issue, but all the worklog are in the subtasks so the remainingEstimate that I see in the parent issue is the sum of all the subtask's remainingEstimate.
I realice that the remainingEstimate is different that Σ remaining estimate and I need to make a query with the second field.
Mohamed Benziane
OK it is why i asked you if you have scriptrunner because what you want is not implemented in JIRA JQL.
All my search send me to an add-on.
Regards
Register now
