Need some assistance on how to we can query issues that are linked between two projects and specific issue types.
For example, we want to find issues that are linked between Project A and Project B and the issue types are Bug and Problem.
I am aware this may be achievable through plugins like ScriptRunner for Jira Cloud, but it is possible to use Jira's own native JQL? Because this query will be used in Backbone Issue Sync for Jira and I believe it only supports Jira's own native JQL, but please do correct me if I am wrong.
Thank you in advance.
Hello @Kelvin Teng
Your query cannot be achieved using only native Jira JQL capabilities.
You can find information about the native JQL capabilities here:
https://support.atlassian.com/jira-software-cloud/docs/what-is-advanced-search-in-jira-cloud/
There is a function called linkedIssues() that enables you to search for issues linked to one specific issue with any or one specific link type. There is no function to find all the linked issues based on the project in which the issues exist.
Hi @Kelvin Teng
I'm Francis - part of the Exalate team, an app which provides similar functionalities like Backbone.
We get the same question and a workaround can be where you populate a custom field with the information you can use to build a standard JQL.
For instance - you could have a custom field 'Remote Key' containing the key of the issue on the other side. The JQL would then be straightforward, selecting the issues where the remote key is filled in.
Hope this helps,
