JQL QUERY
marie.mitchell
I have set up a filter to see all bugs relating to my project board. I have then added a label so that i can add priorities to these bug tickets. Next i have added the label priority as a quick filter so i can easily see/filter on the board all the bugs that are labelled according to the priority.
So my question is, what is the query i need to pull that data in please?
Thank you!
Marie
Veera
January 30, 2020 edited
Hi @marie.mitchell
I am just curious, why can't we use Jira in-built priority field here? What's the need to use Lable field?
marie.mitchell
Hi @Veera @Ollie Guan ,
Yes I can use the existing priority filter - it doesn't need to be a label.
Because i'm new to queries I just wanted to test using a label to see if it returns only the tickets i have tagged as part of the test (we have a huge amount of tickets already using the prioritised function).
Once i know the structure of the query i can edit for label or priority.
Veera
January 30, 2020
Hi @marie.mitchell
Since your requirement is to pull all the bugs on to a board, you may use below JQL in the board filter.
project = "Project Name" and issuetype = Bug
Then you want to have quick filters on the board using label for the priority. So, you can create quick filters as shown in the below screenshot.
I would not recommend this approach as a bug can have multiple labels in it. e.g., User can add 'low' and 'high' labels to the same bug.
With this the quick filter will show the ticket as 'low' priority based on the order of the quick filters defined on the board.
Like • mohithb likes this
marie.mitchell
Hi @Veera ,
Yes i had already set up the initial filter, the one i am looking for is to dig 1 level deeper - so within that bug query, how can i pull out tickets relating to specific labels.
Ollie Guan
Hi @marie.mitchell ,
Do you customize many different labels to reflect priorities? E.g
Label A: High
Label B: Medium
Label C: Low
Or do you use system field priorities?
