JQL Query: Filter issue with no update from Assignee
Martin Ninaj June 25, 2020
I didnt find out how to filter issues, with no update by assignee for specific time. When Assignee did not update issue for 5 hours, I want to see it. I can filter isuses with no updates, but I need specify no updates by current assignee. Is that even possible?
thank you
June 25, 2020
Hi @Martin Ninaj
What is the problem you are trying to solve?  That is, why do you need this information?
Answering these questions will help the community give you ideas to try.
Of note, what you are asking cannot be done easily for out-of-the-box JIRA.  You would need one of the marketplace add-ons.  There is an edge case if you only care about some changes, like status, where you can use something like NOT Status CHANGED BY user AFTER -5h
Best regards,
SERVER
