JQL - Sprint List
Rubia Valiati
How can I get a list using JQL with all projects sprints, start date and end date of each sprint?
Example:
SprintStart DateEnd Date
Sprint 131/07/201920/08/2019
Sprint 221/08/201917/09/2019
Sprint 318/09/201920/09/2019
Thanks.
Thomas Magny-Garcia
September 5, 2019
Hi @Rubia Valiati
I will use an answer from @Nic Brough :
"JQL is for finding issues, not reporting on them.  You'll need a JQL query to get the list of issues you want to report on (So something like "Product in (DEF, GHI)") and then use that in a gadget or report.
The most simple and intuitive report is the issue navigator, where you get the results of a search by default.  Run your JQL, save it as a filter, then (optionally) set the columns to include at least issue type and product.  That will show you the raw data you want to aggregate.
Then go to your dashboard (or add a new one) and add a gadget.  For the case you've got, I would suggest the "2 dimensional filter" gadget, as you can tell that to use your saved filter, and report on maybe an X axis of "issue type" and a Y axis of "product" to get a grid telling you the things in your question."
Hope it helps !
Rubia Valiati
Thank you @Thomas Magny-Garcia !
James Parnell July 4, 2020
Did you have any luck @Rubia Valiati ? I was only able to create a grid using Issues data and not Sprint data like below:
LaTisha Jenkins September 27, 2021
how were you able to generate this?  was it in jira or custom?
Kevin Steen
@LaTisha Jenkins this was created from by using 2 things
  1. A Saved Filter
  2. A gadget in the Dashboard called "Two Dimensional Filter Statistics"
    1. Once you select this gadget, you can choose your saved filter as the source and select your X / Y "axis, similar to an excel pivot chart.
DPKJ
@Rubia ValiatiJQL is for issues only, you can not get Sprint,project,version extra using this.
But you can view list of sprint in Sprint Report - https://confluence.atlassian.com/jirasoftwarecloud/sprint-report-777002722.html
Rubia Valiati
Thank you @DPKJ !
Like • Sanjib Saha likes this
