JQL computations / SQL queries
Lee Correll
May 7, 2012
Is there a way to have the issues function (in short, JQL) in JIRA perform basic computations? I realize it's not a reporting tool, it's used to find and select issues - but I want, say, an indicator for which issues are significantly over their estimates. If it can't be done in JQL, can I run a SQL query instead?
In SQL, I believe that is
select issuekey from {somewhere} where
(timespent + timeestimate) > (1.2*timeoriginalestimate) and
(timespent + timeestimate) > 2
(I'm not sure what aggregatetimespent contains. A total of time spent across iterations, perhaps?)
JamieA
May 8, 2012
There are no analytical functions in JQL... it's not possible. You could write your own JQL function to help you find issues that are 20% past their due date, or you could write a custom field that shows the %age past due date and query on that, but in terms of doing ad hoc analytical stuff, JQL is not the answer.
You can do it in SQL... maybe someone will have an example for that. aggregatetimespent IIRC is time spent including subtask time.
Pablo Beltran
February 28, 2016
Not in Cloud, bit for JIRA server SQL for JIRA exactly does what you are asking for...
JamieA
March 3, 2014
Filipe February 25, 2014
Try if
https://marketplace.atlassian.com/plugins/pt.lt.lfcribeiro.jira.jqlLTFunctions
Solves your problem, it has a executeQuery() JQL that lets you run SQL
Lee Correll
March 3, 2014
Not availble in OnDemand.
Get Certified! ✍️
