JQL filter to show all issues in a project but Done/Closed tickets resolved only in the last 7 days?
Morgan_Thompson February 12, 2020
Pretty much what the title says. I need a filter that will display every issue in a project with the exception that Done/Closed tickets must have been resolved only in the last 7 days. I'm not super great with JQL and have been banging my head against this for awhile.
Thomas Magny-Garcia
February 12, 2020
Hi @Morgan_Thompson
If I understand you should try
project = YOURPROJECT AND resolutiondate > -7d OR resolutiondate is EMPTY
That will give you all recently resolved tickets and the tickets unresolved.
In fact, want you exclude all tickets resolved a long time ago ?
Hope it helps !
Aylin Kohls
February 13, 2020
Hi! only one small thing, use of the parenthesis:
project = YOURPROJECT AND (resolutiondate > -7d OR resolutiondate is EMPTY)
Morgan_Thompson February 13, 2020
This works perfectly. Thank you!
Jack Nolddor _Sweet Bananas_
Hello Morgan,
Try this JQL, using Advanced searching:
References:
Regards
Hi, thanks for your answer. Unfortunately, that JQL only shows issues resolved in the last 7 days. Which is needed, but I also want to show all unresolved issues.
