Is is posible to combine te JQL issue function issueFunction in portfolioChildrenOf and issueFunction issueFunction in subtasksOf?
Explanation:
We have an issuetype initiative and we have an issuetype business epic. Business epics are child issues of the initiatives. We've created sub-tasks which are linked to the business-epics.
What I'm trying to achieve is to make a list of sub-tasks when the key of the initiative is the I only information I have.
It has to be a JQL solution (not scriptrunner) because I need to use te query in a Jira dashboard.
I've tried diffrent ways nesting the JQL's (for one example see below) but that didn't work.
issueFunction in subtasksOf("issueFunction in portfolioChildrenOf("key=Initiative-1")")
Is this even posible and has anyone an idea how to achieve this?
Hi @PEGE
Yes you can use any JQL as a sub-query including issueFunction.
If you are looking to have all subtask under a Business Epic that is linked to Initative-1 you can use:
issueFunction in subtasksOf("issueFunction in portfolioChildrenOf('key=Initiative-1')")
Make sure to use ' and not " in the sub query or you will have to escape them using \"
Reagdrs
Hi @Florian Bonniec ,
Thanks a lot!! It worked!
Spend so much time on this but couldn't get is to work because of that ".
