JQL for drop down values
Devi Vaishnavie December 8, 2022
How to pull data from drop down values (Customized field) in jira via JQL. For instance, if I have a dependent dropdown as follows:
Option 1
  Value a
  Value b
  Value c
Option 2
 Value a
  Value b
  Value c
How could I view tickets mapped against Option1 -->Value b and Option2 --> Value c. Can anyone help me with JQL ?
Matthias Gaiser _K15t_
Hi @Devi Vaishnavie
I'm not exactly sure what you mean with "dependent dropdowns". Could you elaborate on that or maybe include a screenshot?
In general, a JQL for two dropdown values would be:
"Single Select 1[Dropdown]" = B AND "Single Select 2[Dropdown]" = C
Does this help?
Matthias.
If you're talking about the cascading select fields, I'd recommend a JQL like this:
"Cascading Select" in cascadeOption("1","b") or "Cascading Select" in cascadeOption("2","c")
More details about cascadeOption can be found in the docs.
Like # people like this
