JQL for finding all issues linked to a specific type
Aaron S
May 24, 2019
I know this exists to find issues that are linked to a specific issue
issue in linkedIssues(issueKey,linkType)
However, I want to find all issues linked to a specific type, specifically story items.
Ideally i would be looking for something like this (if it exists):
issue in linkedIssueType("story")
Hopefully this makes sense. Thanks in advance.
Petter Gonçalves
May 27, 2019
Hello Aaron,
Unfortunately, JIRA does not have a JQL parameter to return all issues which have linked issues from a determined issue type, if I have properly understood your request.
This kind of "sub-filter" where you will search for issues based in the fields of linked issues can only be achieved in JIRA Cloud by using a plugin, like JQL Search Extensions for JIRA.
The mentioned plugin provides the parameters linksQuery and linkedByQuery, that you can use to return the information you want:
linksQuery = "issuetype = story"
Let me know if this information helps.
Register now
