Hi Atlassian Community,
Prior to migrating to Jira Cloud, our team had some filters to track whether our team has entered or not entered certain fields. One of those fields was a custom dropdown. This has since broken since migration to Jira Cloud.
I've tried the following:
Could you please let me know how I can determine whether a user has selected an option or not?
Note that for the first dot point, I've listed all the possible options besides the empty option (i.e. a non-selection)
Thanks in advance,
Andrew
Hi @Andrew Tran ,
Welcome to the community!
Can you confirm that the field you are looking for is indeed in your new Site on cloud?
I assume that where you type "CustomField[Dropdown]" you replaced this with the actual field name right?
A few screenshots of your JQL would speed up the help you can get on the community.
br
/Lisa
Hi Lisa,
Thanks for your reply. Yes CustomField is replaced with the actual field name (MoSCoW). We've lived with this issue for some time now. I need to update you that the Jira search appears to work now. The only issue remaining is the Jira filter embedded in Confluence does not show the correct result:
When I edit the filter, it also shows 0 issues:
When I click on the "0 issues" link or copy that filter into Jira, I see the correct results (2 tasks):
Note that the filter is exactly the same except "MyTeamName" is replaced with my team's actual name.
Ok good, that your JQL seems to be functional but your Confluence does not seem t to like it?
Have you also migrated a Confluence on prem to Confluence Cloud or are you connecting a Jira Cloud to a Confluence on prem?
I would next to try to run a simpler JQL in the Jira issue/filter macro. like Project in ("MyTeamname") just to see what happens.
/Lisa
Hi Lisa,
I tried a simplified query but I get the same problem:
We migrated from Confluence on prem to Confluence Cloud.
Andrew
