×Hello @Monika Brandström
Below JQL-query worked for me, giving me all subtasks and linked issues to my AC-15 issue:
parent = AC-15 OR key in linkedIssues("AC-15")
What above query says: Fetch all issues that have AC-15 as a parent or whose key is linked with AC-15
How does it work for you?
Hope it helps and good luck!
Can you try
parent = "ISSUEKEY" OR issue in linkedIssues(ISSUEKEY)
Replace the issue key with the issue ID of your story or subtask.
I see the function available in the reference https://confluence.atlassian.com/jirasoftwareserver0713/advanced-searching-functions-reference-965542862.html#Advancedsearching-functionsreference-linkedIssueslinkedIssues()
Hi @Nisha Hajamohideen ,
your solution works great for me in the standard cloud installation. Thanks. I have added an "order by rank" to show the order used in the issue view of jira.
parent = "DOC-9902" ORDER BY rank
Best Regards,
Oliver
Is there an option to arbitrarily leave any ?
Ex: parent = "ISSUEKEY" that works with the key MAR-2 and for other occasions MAR-3
Worked for me, thank a lot @Nisha Hajamohideen
linked issues are different than subtask. how I will find all the subtasks for a story with linked issues?
issueFunction in linkedIssuesOf("Key=JIRA-100") or issueFunction in subtasksOf("key=JIRA-100")
This worked for me too! Thanks a $milli$!
You can try this in the JQL query search text box -
issueFunction in subtasksOf("fixversion=37.0")
You can give your required fix version or use any other filter.
Thank you for all your answers. Parent in and linkedIssues was the solution for me.
JQL Search Extensions for Jira & reports plugin have rich queries which are very useful. You can either use scriptrunner or JQL Search Extensions for Jira & reports plugin.
I am using JQL Search Extensions for Jira & reports plugin and its really amazing.
Following query will be helpful in your case.
It will return all linked issues and sub tasks linked with JQL-3 or JQL-5
issue in linkedBy(JQL-3, JQL-5)
you can find more documentation here
issuekey in childIssuesOf("your parent issuekey-xxxx GOES HERE")
example: issuekey in childIssuesOf("NMER-9549") where NMER-9549 is the Story and the search results would be the subtasks.
In Jira 8,
below works fine
Search Issues ==> Advanced ==> In the query field
parent = <ticket no>
I used this query and it works :)
project = "ProjectName AND issuetype not in standardIssueTypes()
@Monika Brandström You could use a plugin like this one, it works for me!
Once installed, the query should be something similar to:
