I have a custom field called "Create Date" which is a text field which has values like 02/02/2016.... 03/04/2015 ..04/04/2016 etc . as it is a text filed can i query this to find value in range ?
Like find all values between 02/02/2016 And 2027/2016 ?
if Not can i query to find a string that contain "2016"
i tried using "create date" ~ "/2016" but did not work
is " Create Date " a reseved word ?
You've answered your own question - a field that is text cannot have a range searcher, it's not got data that can support it. It's a bit like asking "are those colours between two and four?". The data does not know it might be searchable.
"create date" ~ 2016 will work, but it's going to pick up the 20th January and so-on.
Thanks Nic but i tried running
"Create Date" ~ 2016 in advance JQL query field but it did not return any data am i still missing something ?
Mmm, sorry, that used to work, but now it needs the 2016 to be a word on its own. It won't find partial words, so 20/3/2016 won't be found.
