I have create a field using the Cascade Option. This field does not have a default value. I would like to create a JQL query to select issues for which this field is blank. I managed to create the JQL query to find issues for which this field is in a specific list (e.g. ..... in cascadeOption(10604)) but I struggle to search for blank values.
Could you please tell me how to write this query?
The keyword "none"
can be used to search for issues where either or both of the options have no value. For example:
location in cascadeOption(none)
For reference see Advanced searching function cascadeOption
Ram.
Hi Charles,
You will find your answer here:
https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-functions/
Gabriel
