I'm trying to write a JQL query with component filter with value not equal to Prod, and this gives zero matched issues below is the query used,
project = <projectName> AND component != Prod
NOTE: The respective tickets/issues have component field empty.
Hi @Mohan Kona and welcome to the Community!
If you want to find issues with no component on them, you need to search for them explicitly like this:
Project = <projectName> AND Component IS EMPTY
You can combine that with your previous search if you want to find issues with a different component listed than "Prod"
Project = <projectName> AND (Component IS EMPTY OR Component != "Prod")
Hope this helps!
