JQL status changed by a group member
Rosa M Fossi
August 26, 2020 edited
Hello Community,
I'm trying to query all of the tickets transitioned today INTO "Technical Review" by members for group "it-security"
This query does not work:
project = "Client Support" and created > startOfDay() AND status changed TO "Technical Review" AND status changed BY membersOf("it-security")
If I remove the last portion:
The JQL does resolve with a list of tickets transitioned today into "Technical Review".
I assumed that the membersOf would work since I'm able to query when status changed by a specific user (id has been changed to protect the innocent) like so:
project = "Client Support" and created > startOfDay() AND status changed TO "Technical Review" AND status changed BY "44444:88jea999-999f-7gh0-g7g7-6g5555sed55"
edit:  The error received is A value provided by the function 'membersOf' is invalid for the field 'status'.
6 votes
Dino Dahlin
October 14, 2020 edited
I just had an issue where I wanted to see the the issues claimed fixed by a certain user group
I would suggest trying this
Your line:
This change Adding a bracket around membersOf() worked for me now:
status changed BY (membersof("it-security"))
I hope this helps you!
Erik Hess
This worked for me, thanks for suggesting!
Like • Rosa M Fossi likes this
Rosa M Fossi
March 23, 2021 edited
I missed this post from October by Dino!
I wanted to chime in and mention that this JQL does resolve:
project = "Client Support" and created > startOfMonth() AND status changed TO "Technical Review" AND status changed BY (membersof("it-security"))
Sramanth Pandeti
August 28, 2020
@Rosa M Fossi  what I see from the Official JQL documentation (https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-operators/#WAS) is that You can only have "Username" predicate after BY.
Screen Shot 2020-08-28 at 3.50.44 PM.png .
and the supported fields of membersof() function are Assignee, Reporter, Voter, Watcher, custom fields of type User.
E.g. assignee in membersOf("it-security")
I'm not sure if the below query works for you.
project = "Client Support" and created > startOfWeek() AND status changed TO "Technical Review" AND assignee in membersOf("it-security")
Erik Hess
I'm reasonably certain this worked in the past, as I have multiple queries that worked before that I built years ago. Mine are broken now, and found this when searching for help. The only difference of my query to Rosa's was I did not use double quotes around the group, e.g., membersOf(it-security).
I see the JQL docs don't mention this, so I don't know if the docs changed, or if this was unintended functionality that worked in the past. Frustrated as I'm certain undocumented functionality would not be high on Atlassian's list to fix. :-(
Like • Vignesh Arunachalam likes this
Rosa M Fossi
Sorry to hear your JQLs broke Erik!    I tried without the double quotes (just in case!) but it doesn't resolve.  As the official documentation Sramanth linked it's not listed valid.
My guess is that at some point using the "membersOf" function was edited to only accept userID.
Kirkie
August 26, 2020
The syntax would be
status changed to "Technical Review" BY membersOf("administrators")
Rosa M Fossi
Thanks for your response @Kirkie
Unfortunately, that did not work.  The same error appeared. I even tried simplifying the query a bit just to get it work, but same result.
project = "Client Support" and created > startOfWeek() AND status changed BY membersOf("it-security")
The error seems to imply that the query is checking the membersOf input against status itself.    ¯\_(⊙︿⊙)_/¯
Kirkie
August 27, 2020
project = "Client Support" and created > startOfWeek() AND status changed TO "Technical Review" BY membersOf("it-security")
 Can you tell me if the above works?
Rosa M Fossi
Thanks for your willingness to help!   Sadly the same error    ಠ_ಠ
