A team was deleted from Jira, while still being populated in the Team field for some issues. I noticed that in filter results the Team field is now showing "Not Available." The Team field apparently still retains the deleted team's ID.
Is there a way in JQL to filter for issues where the Team field is populated with a no-longer-valid team ID?
(Note: the Team field isn't empty, so "Team[Team]" is Empty isn't an option)
Hi
It's certainly not the best solution, but if you know the ID of the deleted team, you can add
"where team <> ID No." to the query.
Regards
Thanks, @VronikThat would certainly work for a one-off situation where the ID was known.
I was really looking for a generic solution for all invalid IDs, sort of like the inactiveUser() function that can be used for people fields.
I've created a Jira feature suggestion for a JQL function to return invalid Team IDs.
Thanks again, @Vronik
