JQL to full all the Stories from Features with a condition
Katrina Atkinson November 7, 2024
I have a filter that pulls all the Features with a certain condition (label applied); how do I then create a JQL that shows me all the stories linked to the features under this filter?
(Enterprise Jira)
Hannes Obweger - JXL for Jira
Hi @Katrina Atkinson
Unfortunately, this is trickier than one might think; as a hierarchical query, it would really require some kind of "join" or "subquery", which isn't available in plain Jira/JQL.
A few directions forward:
  • If it's a one-off thing, you could first query the relevant features, and then use the keys of these features in a second query, in a "parent in (KEY-1, KEY-2, ...)" clause.
If you want to run your search dynamically, without manually "stitching" two queries together, you'll need extra tooling:
  • You might be able to use Jira Automation to "propagate" feature information down to the feature's children, and then use the respective field(s) on the children to include them into your filter. Obviously, this will add a fair bit of complexity to your system.
  • There's different apps from the Atlassian Marketplace that can help with that. First, there's a number of apps that extend JQL by additional functions, including hierarchy-related functions. I've used JQL Search Extensions a few times and it works well.
  • Alternatively, you could try one of the more hierarchy-focused apps from the Marketplace. These apps typically have their own ways of figuring out parent/child relationships between issues, and provide more powerful ways of searching through issue hierarchies. I myself work on such an app, in which your use case would be easy to solve - I'll provide more details below.
Hope this helps,
Best,
Hannes
... and just to expand on the last point: This is how this would look in the app that my team and I are working on, JXL for Jira. Put simply, you'd create a sheet with all issues that are potentially relevant to you, model your issue hierarchy (if you're using the default hierarchy, that's just one click), and then use JXL filtering capabilities to narrow down to the issues that you care about:
Once you have your list of issues, you can work on these directly in JXL (much like you'd do in e.g. Excel or Google Sheets), trigger various operations in Jira, or export them for further processing.
Any questions just let me know!
Trudy Claspill
November 7, 2024
Hello @Katrina Atkinson
There is not a method to do that with only native Jira JQL functionality.
The portfolioChildIssuesOf() enables you to do that sort of query for one explicitly specified Feature at a time. You can't provide a filter as the input for the Features in that case.
What do you want to do with the results?
A workaround using an Automation Rule could be possible. A Scheduled trigger could use the JQL you have to select the features, and then you can use the portfolioChildIssuesOf() repeatedly to get the child issues of each feature. The results can be sent to users via email.
Otherwise, are you willing to consider a third party app to achieve your requirement?
