JQL to get issues commented by an user in a period
Sara
Hello, I need to get all issues commented by an user in the last week, is that possible in jira cloud? How?! Thanks in advance.
Walter Buggenhout
Hi @Sara,
That is unfortunately not a search supported natively in Jira, but it can be done with marketplace apps like Scriptrunner or JQL Search Extensions.
Hope this helps!
Prosper Agwegiokhe
Hi @Sara,
I’m Prosper, a support engineer at Appfire, and I’m here to help you.
As @Walter Buggenhout  has said, this isn't supported natively in Jira, but if you are open to 3rd party solutions, the app I work for, JQL Search Extensions for Jira, you can use the query below to get the results for your use case:
commentedByUser = "{username}" and commentLastCreatedOnDate > -7d
You can see more information about this query here, and please contact our support if you have any other questions about this query.
We’ll be happy to help you!
Best regards,
Prosper.
