JRJC throwing JSONException sporadically
Yarin Benado February 22, 2013
It appears like on few REST calls (createIssue() for example), JRJC will receive an empty string for a result and will throw the exception below. Calling the REST method again works though, so I have to make the following hack:
int tries = 0;
do {
    try {
        basicIssue = issueClient.createIssue(in).claim();
        tries = 1000000;
    } catch (Exception e) {
        tries++;
        System.err.println("Failed creating issue!");
        e.printStackTrace();
} while (tries <= 3);
com.atlassian.jira.rest.client.api.RestClientException: org.codehaus.jettison.json.JSONException: A JSONObject text must begin with '{' at character 0 of
	at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:181)
	at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:175)
	at com.atlassian.httpclient.api.ResponsePromiseMapFunction.apply(ResponsePromiseMapFunction.java:62)
	at com.atlassian.httpclient.api.ResponsePromiseMapFunction.apply(ResponsePromiseMapFunction.java:12)
	at com.atlassian.util.concurrent.Promises$Of$3.apply(Promises.java:285)
	at com.atlassian.util.concurrent.Promises$2.onSuccess(Promises.java:162)
	at com.google.common.util.concurrent.Futures$7.run(Futures.java:1072)
	at com.google.common.util.concurrent.MoreExecutors$SameThreadExecutorService.execute(MoreExecutors.java:253)
	at com.google.common.util.concurrent.ExecutionList$RunnableExecutorPair.execute(ExecutionList.java:161)
	at com.google.common.util.concurrent.ExecutionList.execute(ExecutionList.java:146)
	at com.google.common.util.concurrent.AbstractFuture.done(AbstractFuture.java:235)
	at com.google.common.util.concurrent.AbstractFuture.set(AbstractFuture.java:172)
	at com.google.common.util.concurrent.SettableFuture.set(SettableFuture.java:53)
	at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient$1$1.run(SettableFuturePromiseHttpPromiseAsyncClient.java:46)
	at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient$ThreadLocalDelegateRunnable$1.run(SettableFuturePromiseHttpPromiseAsyncClient.java:197)
	at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient.runInContext(SettableFuturePromiseHttpPromiseAsyncClient.java:90)
	at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient$ThreadLocalDelegateRunnable.run(SettableFuturePromiseHttpPromiseAsyncClient.java:192)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
	at java.lang.Thread.run(Thread.java:722)
Caused by: org.codehaus.jettison.json.JSONException: A JSONObject text must begin with '{' at character 0 of
	at org.codehaus.jettison.json.JSONTokener.syntaxError(JSONTokener.java:439)
	at org.codehaus.jettison.json.JSONObject.<init>(JSONObject.java:169)
	at org.codehaus.jettison.json.JSONObject.<init>(JSONObject.java:266)
	at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$1.handle(AbstractAsynchronousRestClient.java:138)
	at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:179)
	... 28 more
OmarA
February 24, 2013
Hi Yarin,
Also you may need to report this to https://ecosystem.atlassian.net/browse/JRJC so our developers can take a look at it.
Omar
It appears like JRJC 2.0.0 is too immature. Ported the code back to JRJC 1.0.0 and it no weird async things happen.
Aleksander Mierzwicki
April 14, 2013
I've replied in https://ecosystem.atlassian.net/browse/JRJC-146 - we need more details to track this issue. The 2.0.0-m16 should be quite stable (not many changes are planed for 2.0 release).
P.S. Next time please add jira-rest-java-client tag, so we'll get notified about new question related to JRJC.
Using JRJC 2.0.0-m8 and 2.0.0-m9. same behavior
Register today
