JSON import to JIRA 7.1.2 (Server) - how to account for project type?
Rose Cruz
Regarding JIRA Software (Server) v7.1.2 - having issues with importing JSON file. Used the JSON format example on the page Importing data from JSON. I experienced the bug (JIM-1668): JSON project "type" is required for jira 7 and not marked as ignorable. I also read that the documentation has not been updated to account for Project Types (JRA-45676). Can someone provide an update?
Petar Petrov (Appfire)
June 10, 2016
I believe you are missing the project type which is required for JIRA 7.x. Add a "type" property with value "software" or "business" (depending on what type of project you want to create).
Rose Cruz
Thanks for the quick response Petar. Where does the property go exactly in the json file, can you provide an example?
June 10, 2016
It should be in the project object. If I take an excerpt from the example in the documentation:
"projects": [
            "name": "A Sample Project",
            "key": "ASM",
            "description": "JSON file description",
			"type": "software",
            "versions": [
