Hi all,
On an issue screen, I've got two listbox fields list1 and list2. I wonder if it was possible to choose a value in list1. And list2 will be enabled or disabled, according to the value selected in list1.
In my above example, list1 contains both "Yes" and "No"
If I choose "Yes" list2 will be enabled, otherwise, it will be disabled. Is this possible to do that on a JIRA issue screen ?
Thanks a lot,
Any help greatly appreciated.
try with this script by changing custom field ids as per your instance
<script type="text/javascript"> jQuery(document).ready(function($) { JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) { callHideShowFunction(); }); callHideShowFunction(); function callHideShowFunction(){ showHideSelectList(); $("#customfield_11704").closest('div.field-group').hide(); $('#customfield_11911').change(function() { showHideSelectList(); }); } function showHideSelectList(){ var emergencyImpl=$.trim($("#customfield_11911 :selected").text()) if( emergencyImpl == "Yes" ){ $("#customfield_11704").closest('div.field-group').show(); }else { $('#customfield_11704').val(''); $("#customfield_11704").closest('div.field-group').hide(); } } }); </script>
i think you can convert list1 to radio button because it have only two values, if you want use radio button then you can have solutiion here
Well, it does not matter ! Do not annoy you with that, it is already very nice that you help me! : -)
Thanks a lot... I will find another way ;-)
So, I create an issue. I have an alert emergencyImpl:None. I click on OK and then have an other alert emergencyImpl value is No. I click OK. Another time emergencyImpl:None. And then emergencyImpl value is No.
I choose Yes in my list1, I have an alert : emergencyImpl : Yes ... and then an other : emergencyImpl value is Yes, and then emergencyImpl : Yes, and then emergencyImpl value is Yes
I choose No in my list2, I have an alert : emergencyImpl : No ... and then emergencyImpl value is No .... and then emergencyImpl : No and then emergencyImpl value is No
this is weired!! i am not sure why it is triggering onchange event for list 2 field :(
your code seems correct except minor change, try with this
<script type="text/javascript"> jQuery(document).ready(function($) { JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) { callHideShowFunction(); }); callHideShowFunction(); function callHideShowFunction(){ showHideSelectList(); $('#customfield_10903').change(function() { showHideSelectList(); }); } function showHideSelectList(){ var emergencyImpl=$.trim($("#customfield_10903 :selected").text()); alert("emergencyImpl: "+emergencyImpl); $("#customfield_10902").closest('div.field-group').hide(); if( emergencyImpl == "Yes" ){ alert("emergencyImpl value is Yes"); $("#customfield_10902").closest('div.field-group').show(); }else { alert("emergencyImpl value is No"); $('#customfield_10902').val(''); $("#customfield_10902").closest('div.field-group').hide(); } } }); </script>
add the above script in list2 field description
it does not work... result is similar. On the issue modification screen I cannot modify the value of list2 :-(
i have updated my answer with alerts so try with that and let me know what alerts are popup!!
is it worked? what was the problem?
Thanks, you're great ! :-) I did not know a lot about javascript language unfortunately :-(
Here is my code. I follow your advice (I prefer to continue with listbox instead of radio button), but it still does not work on modification screen...
}else {
</script>
which one is list1 and list2 field ?
is list1 is customfield_10902 and list 2 is customfield_10903, is it correct or i am wrong?
Rambanam, first of all, thank you very much for your quick answer.
Then, I've tried to use your code. But I met a problem when I try to modify my issue : first field list1 is filled with the value I've selected ("Yes"), the other one, list2, too. But when I try to modify list2, it erases its value and list2 becomes invisible ...what can I do to solve this problem ? in the issue modification screen, I'v tried to modify list1 thinking that list2 appears with correct value, but list2 is still not visible...
can you share your custom field id's/script so i can debug it!!
