Hi
I am able to add comment to issue in Jira through API but i am struggling to mention/tag user in that comment i am using below API
curl -D- -u admin:adminxyz-X POST --data '{"body": {"type": "mention","attrs": { "id": "xyz","text": "hi @XYZ "}}}' -H "Content-type: application/json" https://myjira-prod.com/rest/api/2/issue/Test-123/comment
i am getting below error
{"errorMessages":["Can not deserialize instance of java.lang.String out of START_OBJECT token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@6851c17a; line: 1, column: 2] (through reference chain: com.atlassian.jira.issue.fields.rest.json.beans.CommentJsonBean[\"body\"])"]}+
Just to clarify, in practive it looks like: [~accountid:5c6b8ee0e1bcdf6294d08676]. Spend some time to figure the final state
Hey Pravin,
Check this one,
curl D -u username:password -X POST --data '{"type":"mention","body":"hi [~user]"}' -H "Content-Type: application/json" http://myjira:8080/rest/api/2/issue/COM-1/comment
Sunil
Hi Sunil, I am getting the below result when using "hi [~pamishra]" (where "pamishra" is a valid user name) to tag a user in the comment, this "User" when clicked takes me to a page saying the user does not exist.
I also need an answer for this issue
Make sure you have a valid user. This works and has been tested.
Hi @Lorna Jones , found a way through this, after recent updates [~<username>] does not work in order to tag a user in JIRA comment.
Try [~accountid:{<accountid>}].
This worked for me.
thanks for replying, that is the work-around I came to the conclusion of as well! :) - I do wish this was documented a bit better, rather than letting users stumble through forums for useful comments!
[~accountid:{<accountid>}] does work, is there any official documentation about this?
Wrong! It still works. Probably you are formatig the string not properly. your finall string should looks like something similar (with different accountId value) to this:
[~accountid:712010:587cdfd3-1064-41ce-9637-da9a4da55666]
Register now
