Jira Admin: List of Field Screens do not appear
Douglas Cuffman February 8, 2018
I know this is probably my fault, but for some reason the list of field screens in Jira admin no longer display.
Path: MySiteName.atlassian.net/secure/admin/ViewFieldScreens.jspa
Can anyone help?
DC
KellyW
February 25, 2018
Hi DC,
Sometimes this kind of issue happens when there is orphaned workflow object in the database -- screen associated with the workflow is removed. If that's the case, please identify the screen ID that JIRA is failing to locate ( e.g.:
Caused by: java.lang.IllegalArgumentException: Cannot find Screen with id '10800'.
) and run the following SQL query to identify the relevant workflow:
SELECT * FROM jiraworkflows WHERE DESCRIPTOR LIKE '%10800%’;
* replace 10800 with the relevant screen ID *
Remove or update the identified workflow object accordingly.
If issue persist, please try with Incognito internet browser session or clear the browser cache & cookie and test again.
Kelly
