Jira Assets attribute object reference multi select
Michael Frade
In Jira Assets, if you have an attribute that is a reference to another object, is there a way to have multi select.  So if the attribute is a linked to an employee object schema and you want to be able to associate multiple employees for that attribute as like a POC, is that possible?
Mikael Sandberg
Yes, that is possible. What you need to do is set the cardinality to unlimited, similar to what I have done for the attribute catalog:
Michael Frade
I went round and round. Thank you!
Like • Mikael Sandberg likes this
Özlem Bilican
October 24, 2024 edited
Hi, when importing assets with csv, what format should we write it in to the document?
I found :)
in CSV document:
Name
Environment
Test App
Test||Production||Development
 Jira import AQL:
Label IN (${Environment${0}})
Let's build A Rovo Agent 🤖
Save your spot
