  • Community
  • Q&A
  • Jira
  • Questions
  • Jira Automation - Clone story then email, email does not show {{issue.parent.key}} {{issue.parent.s
Laura Hanna
I have a story that I am cloning. This copied the Parent Link.
The cloned story looks fine, it includes the link. It has it showing "as child of" in the story.
This is all good.
But, when I send an email after this with  {{issue.parent.key}} {{issue.parent.summary}}
It shows up as blank. The email is suppose to alert that there is a story created and it is part of the "main story".
In the "send email"
Decommission the following as per:</p>
Main Story: {{issue.parent.key}} {{issue.parent.summary}}<br /> {{issue.parent.url}}<br />
Email:
3 votes
Murat Seven
January 12, 2024
You can use the smart value {{createdIssue}} to access the last created issue in the rule.
or
you can try the below smart values:
{{issue.issuelinks.inwardIssue.key}}
{{issue.issuelinks.outwardIssue.key}}
Best,
Murat Seven
Laura Hanna
Unfortunately, non of these work. Still Blank.
{{createdIssue.key}}
Laura Hanna
Correction!
Both work! Thank you!
Like # people like this
