Dear community,
I'm trying to write an automation for the following use case:
I would like to receive an email everytime the release is changed within an existing object.
In the features, the release is described in the labels as follows:
R_21, R_22, ... and so on. In other words, the old and new release will differ in the digits after the R_
Can someone help me how to write the formula for this in the automation? I searched back and forth, but somehow it won't work...
Many thanks in advance and BR
Eva
Following can help you. When field labels is changed during edit issue then email is sent.
Thank you for your reply and your suggestion!
Important to mention that there are multiple values in labels, not only the lable for the release. So the condition would have to refer specifically to the expression "R_...".
So I am afraid your approach won't work in my case. Thank you very much though!
