×Hello,
I've created an automation rule with a query which finds 4 issues.
Unfortunately, when I run the rule, it does not perform any action, saying "No related issues could be found".
What can I do to solve this?
Thank you.
Hi @Duarte ,
did you remember to uncheck the box that says "Only include issues that have changed since the last time this rule executed" ? This might be the reason why your rule does not run for any issues :
Let me know if this helps,
--Alexis
@Alexis Robert thank you for your reply. First, that option was checked, but even after I've removed it, I still have the problem.
