Please read this carefully: I am asking a question about the Jira Automation REST API (allegedly
https://developer.atlassian.com/cloud/automation/rest/api-group-rest/#api-group-rest) .
I am NOT ASKING -- NOT ASKING -- How to incorporate an API call in a Jira Automation.
Anyone on Jira Cloud using Postman (or command line cURLs) able to successfully search for templates using GET or POST ? I'm using Postman with all my similar setup for Jira and Confluence REST goodness. I am a regular API user so I don't think we need to diagnose my authentication or anything like that but it's not out of the question cause headers and such... But anyways...
Here's the URL I am trying:
<mySiteURL>/automation/public/jira/<myJiraCloudOrgID>/rest/v1/template/search
This returns: 404 not found
I'm not looking for much from this super basic API. I'd really just love to be able to grab the JSON for a rule I wrote to use as reference.
- Christa
The document mentions to use <cloudId> and not the <OrgId> I believe that's why you're getting the 404 error because the resource doesn't exist. This document shows how you can retrieve your site cloud ID
@Prince Nyeche You, my friend, are a genius!
Using the document above to obtain my site's <cloudId>, and re-reading the API documentation I was eventually able to get it to work in Postman. Here's the URL I used:
https://api.atlassian.com/automation/public/jira/<cloudId>/rest/v1/template/search
Note: The url is indeed https://api.atlassian.com/ Not the URL for your product access.
Note #2: That's atlassian.COM not atlassian.NET
I am guessing that endpoint's usage is license level specific as it still does not work for a free license level when I just tried it.
Odd. It worked for me on my personal Free tier.
The original question was for a Premium tier Jira so that's a good call out!
If I understand your question, there is no public REST API to access automation rules (or their audit logs) yet: https://jira.atlassian.com/browse/AUTO-51
Anything you may see posted in the community about people "discovering" such endpoints is likely to be unsupported and undocumented.
If there is no public API then why does this Atlassian created and managed documentation exist? https://developer.atlassian.com/cloud/automation/rest/api-group-rest/#api-group-rest
Well, I have never seen that documentation page before. And, none of them worked when I did a quick test (including the simple search with no params)...so perhaps they are not publicly available.
You can export your automation rules to a JSON file, but as @Bill Sheboy has stated there is no public REST API yet.
Export your automation rules to a JSON file
Jira automation provides a quick way to export all your automation data into one file.
In Jira settings, select System > Automation rules. You’ll be navigated to the global Automation screen.
In the top right corner, select … > Export rules. This will download a JSON file containing all global and project-scoped automation rules.
