Jira Automation for budget/cost sum per epic
Jennifer Weber February 26, 2024
We added a numeric field to our issues in which we put the cost of this specific task. It should be added to the budget of the linked epic when it is updated.
Can anyone share ideas how we could implement this?
Stefan Salzl
February 26, 2024
Hi @Jennifer Weber
welcome to the community.
So just to clarify that I got it correctly:
Whenever one of the child issues‘ codt field of an epic is updated the costs of all children should be summed and the sum should be written into same field in the epic?
Could you confirm that?
Best
Stefan
Hi @Stefan Salzl - yes exactly this is what we would like to do!
If using different fields or sth like that would make it easier we are flexible on that.
Stefan Salzl
March 4, 2024
Alright. I would suggest the following way:
Trigger:
  • when
    • field value of your "cost" field changes
    • condition: only start when the changed field´s issue has a parent/EPIC
  • then:
    • collect all children of that epic (via lookupIssue)
  • branch:
    • to Epic
    • within the epic (as you then are in the context of the epic) edit field "budget"
      • fill in sum of lookupIssues´ field "cost" via smart value
      • {{lookupIssues.cost.sum}}
See screenshot below (in my case I used the field "Number 1" in both child task and Epic).
Hope this is helpful. In case of any further questions just let us know.
Best
Stefan
Jennifer Weber March 5, 2024
Thanks a lot! The automation does work but somehow it does not find any issues in the lookup-step, although there should be several. What could be wrong here?
=> No issues were found when searching for a user-defined value.
Just found the solution here => https://support.atlassian.com/jira-service-management-cloud/docs/jql-fields/#Epic-link
2024-03-05 10_06_20-JQL fields _ Jira Service Management Cloud _ Atlassian Support.png
If I use "parent" instead of "epic link" it works perfectly. Thank you @Stefan Salzl
Like Stefan Salzl likes this
Stefan Salzl
March 5, 2024
Nachdem dein Screenshot auf Deutsch ist können wir vermutlich auch in unserer Muttersprache kommunizieren :)
Freut mich sehr zu hören dass es funktioniert hat und dass ich helfen konnte.
LG
Stefan
