I am unable to get the conditions right.
The trigger is Issue created but am not sure how to get the condition "if the issue's summary is already present in the project" work.
you can't prevent the creation but you could create post-creation automation to close as duplicate. Automation works post-creation not pre-creation.
Thank you for the answer.
So the trigger is Issue created?
What is the condition? I have tried JQL with Project = XXX and it did not work.
Hi @Jiri Pik
Yes, the trigger would be Issue Created...and due to potential timing issues you might want to add a re-fetch so the item is fully loaded.
Your JQL would check for any issues in your project which have the triggering issue's summary.
Perhaps something like this.
Best regards,
