Anyone else constantly fight with the card printing feature?? Should be simple to print 4x6 index cards but the whole designer thing is clunky. The margins are never quite right and the print comes out un-centered. What's worse is once you get it fairly acceptable something changes and everything goes out of whack again, causing hours of more tweaking. What's the deal???
Not sure I understand your question, are they not all on a "board"? My printing issue isn't active sprint or backlog related any way, it's about the card designer & constant changes, reverting margins, etc. I can try to print everything in my active sprint at once or open a single issue on its own and try to print with the same issues.
It's just not consistent and every few weeks I have to tweak my saved card design template to get them to not cut off text on my 4x6 cards. It's a major issue that takes a couple of hours to tweak & test print until it's right again.
Check the following and see if they can help:
https://confluence.atlassian.com/jirasoftwarecloud/printing-issue-cards-785332012.html
https://confluence.atlassian.com/jirasoftwareserver074/customizing-cards-889531308.html
Are you a Jira Cloud? Or Jira Server?
Best,
Fadoua
