Jira Classic project type no longer available
ryan carroll April 1, 2015
After the most recent auto update to JIRA there is no longer a "JIRA Classic" project type when creating a new project.
This "update" does not allow us to continue using JIRA as we have been and now when a user creates a project, a new workflow and issue scheme is created every time they create a project which is not optimal at all.
Is there anyway to Re-enable "JIRA Classic "
Version6.4-OD-16-006
Build Number64014
Build DateTue Mar 24 00:00:00 EDT 2015
Build Revisione47e3fa9ffcc5dfe1abb9ad8079120623d9886be
Installation Typeunknown
Server IDBSIQ-MD7C-SZ5L-MF2F
Last Upgrade22/Feb/15 9:56 PM (v6.4-OD-14-082#64012)
cgauterio
April 1, 2015
Hi Ryan,
The JIRA Classic is now known as JIRA Default Schemes project type.
Please give it a try as I believe it will suit your needs.
Clarissa.
Nic Brough -Adaptavist-
April 1, 2015
It does - on Server, but it's been removed from Cloud!
MattS
April 1, 2015
I reccomended contacting Cloud support to see if they can reenable it
Andy Bupp April 28, 2015
Yeah - I logged a bug at https://support.atlassian.com/servicedesk/customer/portal/23
and they resolved the issue quickly.
Shawn Forth April 28, 2015
Any update on this?  I'm encountering the same issue.
April 28, 2015
Have you logged an issue with Support to get it changed for you?
Felipevsw
April 7, 2015
Hi all!
This was an internal setting that was turned on for some customers only. If you want it disabled simply open a support request at https://support.atlassian.com and we'll disable it in your instance.
-Felipe
Robin Rodgers April 8, 2015
Im not sure i understand...If i file a request you will disable all the new project types and give me back the old ones? Or is your answer in regards to the language thing Victor mentioned?
Andyb April 14, 2015
Yes please specify. This is really annoying. I just want JIRA to work- which is why we switch to OD in the firt place/
Victor Paredes April 7, 2015
if you change the default language for the user you could see "Esquemas Predeterminados de JIRA" what is meaning "JIRA Default Schemes"
I need activate this schema in the original language of the user ( english ). how i can do that?
ryan carroll April 2, 2015
Thank you for raising this to the cloud team. I will follow up through that ticket.
MikeyS
April 1, 2015
I've raised an issue for this https://jira.atlassian.com/browse/CLOUD-7806
Clarissa,
Thanks, but with this newest build that is not an option. Below are the "Project Types" that are available to us when creating a new project.
MattS
April 1, 2015
Another colleague noticed this in Cloud. We can't manage enterprise scale JIRA without it
