On our Jira Cloud we have a Components field which is of multi-select, so if Component contains one of its value as “Test”, I have to hide the “Acceptance Criteria” multi select field.
I was able to conditionally hide/show fields for single select but for multi select and components fields I am having trouble to hide/show other fields.
Any help on this request will be highly appreciated.
Welcome to the community!
What are you using today to hide/show fields? Usually this functionality requires a plugin.
Fabian
Hi Fabian,
Sorry I forgot to mention about it in my previous post. We are using Script Runner for Jira Cloud and Behavior's.
Below is the sample behavior script:
I believe it may not be supported. I had the same issue with the "Multiple User Groups" fields and it's not supported. I suggest you contact Adaptivist about the "components" field. Cloud has a lot of limitations.
Fabian
