Jira Cloud Migration Assistant - Issue
Kyu Lee
April 24, 2020
I'm using the Jira Cloud Migration Assistant to migrate projects to the cloud.  I create a test project with the test stories in order to test this migration.  Everything checks out but then i run the migration I get this error.
2020-04-24 16:21:51.445 ERROR TM project-export We couldn't export Field Layout Scheme default. Reason: java.lang.IllegalStateException: entity.id must not be null.
I tried searching for Field Layout Schemes but I could not find anything.  Any help would be appreciated.
Tobias Meyer November 15, 2021
Hello all
I run into the same error today:
2021-11-15 08:50:17.372 ERROR XXX project-export We couldn't export Field Layout Scheme 'Field Configuration Scheme Default'. Reason: java.lang.NullPointerException: entity.id must not be null.
Then I created a new Field Configuration Scheme and I copied the Default Field Configuration.
Assigned the copied Default Field Configuration to the newly created Field Configuration Scheme and associated the Scheme to the desired project.
Hope this helps also other users.
Stefan Zander May 3, 2021
Hi, I have the exact same problem like in the topic starter,
For every project at our Jira Server.
2021-05-03 13:33:07.897 ERROR XXX project-export We couldn't export Field Layout Scheme default. Reason: java.lang.NullPointerException: entity.id must not be null.
Can anyone help?
I am stuck on this for weeks now
brad-anderson May 10, 2021
Same issue here. Created a ticket with Atlassian. I'll update this thread with any findings.
Stefan Zander May 12, 2021
Looking forward to your answer :)
brad-anderson May 12, 2021
Atlassian said we need to upgrade the Server instance for migration to succeed. Others say their instance is on the current release with the same failure. We'll jump through that hoop and report back.
We're also on the latest release
Stefan Zander May 17, 2021
@brad-anderson Do you have any news on this topic?
Loic Yannou May 19, 2021
Hi everyone
Same issues while my previous migrations (2 weeks ago) were working
@brad-anderson do you have any news from the Atlassian support, please ?
brad-anderson May 19, 2021
They got back to me quickly. However, there isn't an easy fix. This is the gist of their response: "Unfortunately JCMA plugin is still a WIP which is actively being improved but still misses some features. Please, check this page  to see what gets migrated by the plugin."
We'll likely abandon the migration because it is too much of a lift to get into a system that is getting increasingly locked down. The result will be prices will go up and it'll be more difficult to migrate away from later on.
Loic Yannou May 20, 2021
Thank you @brad-anderson
Fyi, Atlassian released a new version (1.5.4) of the add-on
brad-anderson May 20, 2021
Thank you. It's good to see improvements to the migration plugin.
Sameer Bhangale September 4, 2020
Hello Everyone,
Facing same issue,
2020-09-04 12:23:03.600 ERROR ABC project-export We couldn't export Work Log 10072. Reason: java.lang.IllegalStateException: entity.id must not be null.
How to resolve?
Alejandro Alvarez Vazquez July 20, 2020
i have the same error. Using scriptrunner.
Brant Schroeder
Are you using any apps from the Atlassian Marketplace that could affect your custom fields or workflows?
Get Certified! ✍️
