'Jira Cloud Migration Assistant' failed to load.
Guido Sicoli April 2, 2023
'com.atlassian.jira.migration.jira-migration-plugin' - 'Jira Cloud Migration Assistant' failed to load.
Error creating bean with name 'v3SiteAttachmentWorker' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/workers/attachments/V3SiteAttachmentWorker.class]: Unsatisfied dependency expressed through constructor parameter 4; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'attachmentMigrator' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/workers/attachments/AttachmentMigrator.class]: Unsatisfied dependency expressed through constructor parameter 4; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'mediaUploadLogger' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/workers/attachments/MediaUploadLogger.class]: Unsatisfied dependency expressed through constructor parameter 0; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'migrationLogsService' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/log/MigrationLogsService.class]: Unsatisfied dependency expressed through constructor parameter 5; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'logTagProcessor' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/log/LogTagProcessor.class]: Unsatisfied dependency expressed through constructor parameter 0; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'entityIdentifierGenerator' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/log/EntityIdentifierGenerator.class]: Unsatisfied dependency expressed through constructor parameter 0; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'defaultEntityResolver' defined in URL [bundle://86.0:1/com/atlassian/jira/migration/log/DefaultEntityResolver.class]: Unsatisfied dependency expressed through constructor parameter 31; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jswEntityResolver' defined in OSGi resource[classpath:com/atlassian/jira/migration/config/MainSpringConfiguration.class|bnd.id=86|bnd.sym=com.atlassian.jira.migration.jira-migration-plugin]: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [com.atlassian.jira.migration.log.JSWEntityResolver]: Factory method 'jswEntityResolver' threw exception; nested exception is java.lang.NoClassDefFoundError: com/atlassian/greenhopper/service/rapid/view/RapidViewService
com.atlassian.greenhopper.service.rapid.view.RapidViewService not found by com.atlassian.jira.migration.jira-migration-plugin [86]
It was loaded from /var/atlassian/application-data/jira/plugins/installed-plugins/plugin.307800136796948976.jira-migration-plugin-1.8.2.jar
Yong Yang
I have the same issue:
Mayur Jadhav
Hello @Guido Sicoli
I hope you are doing well!!
First of all, please try to clean plugin cache and restart:
Please perform the following actions:
  • Shut down JIRA.
  • Delete the following hidden plugin cache directories:
    JIRA_HOME/plugins/.bundled-plugins
    JIRA_HOME/plugins/.osgi-plugins
  • Restart JIRA (These directories will be recreated on JIRA reboot with new plugin cache)
Please let me know if it works.
Mayur
SERVER
VERSION
8.0.2
