I have a Java application that is using jira-rest-java-client-core version 5.1.6 to create tickets in Jira Cloud and add comments to these tickets.
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-rest-java-client-core</artifactId>
<version>5.1.6</version>
</dependency>
Everything was working, and there were no changes to the code. On Feb. 14, 2020 we started getting exceptions.
Caused by: org.codehaus.jettison.json.JSONException: JSONObject["name"] not found.
at org.codehaus.jettison.json.JSONObject.get(JSONObject.java:360)
at org.codehaus.jettison.json.JSONObject.getString(JSONObject.java:487)
at com.atlassian.jira.rest.client.internal.json.JsonParseUtil.parseBasicUser(JsonParseUtil.java:192)
at com.atlassian.jira.rest.client.internal.json.UserJsonParser.parse(UserJsonParser.java:34)
at com.atlassian.jira.rest.client.internal.json.UserJsonParser.parse(UserJsonParser.java:31)
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.getOptionalNestedField(IssueJsonParser.java:300)
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.parse(IssueJsonParser.java:235)
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.parse(IssueJsonParser.java:88)
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$1.handle(AbstractAsynchronousRestClient.java:148)
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:189)
... 15 more
I know Atlassian has been making changes to remove user names from the API. This makes total sense. The thing is, my code isn't trying to get any user information.
My code that is failing is:
public void createComment(Message message, String username) {
IssueRestClient issueRestClient = jiraRestClient.getIssueClient();
URI issueUri = issueRestClient.getIssue(message.getChat().getJiraIssueKey()).claim().getCommentsUri();
issueRestClient.addComment(issueUri, commentFactory.create(message, username)).claim();
Digging into this more, the problem seems to be in the Jira class
com.atlassian.jira.rest.client.internal.json.JsonParseUtil on line 192
@Nullable
public static BasicUser parseBasicUser(@Nullable JSONObject json) throws JSONException {
if (json == null) {
return null;
} else {
String username = json.getString("name");
if (!json.has("self") && "Anonymous".equals(username)) {
return null;
} else {
URI selfUri = optSelfUri(json, BasicUser.INCOMPLETE_URI);
return new BasicUser(selfUri, username, json.optString("displayName", (String)null));
Is there an updated version of the jira-rest-java-client-core library?
Is this a Jira bug or something else?
Is there a workaround?
There is a similar issue for this but in that issue, they are actually trying to get the user name. I don't care about the username.
https://community.atlassian.com/t5/Jira-questions/JIRA-REST-API-missing-parameters/qaq-p/1302944#U1303392
It's the same problem. In order to parse the issue, it also needs to parse the names in it, like reporter, assignee etc. It can't because "name" isn't optional. The workaround is in the issue you linked, and the better solution is to not use JRJC for Jira cloud because they've stated here -- https://ecosystem.atlassian.net/wiki/spaces/JRJC/overview that JRJC isn't compatible with Jira Cloud.
Supporting Jira Cloud must be nearly impossible, as it's supporting a moving target with a static library.
That said, I'd be surprised if this issue isn't effecting Jira Server.
There was a change to the Jira back end, to stop returning "name".
And, the Jira code in JsonParseUtil is expecting a "name" value.
I'm facing the same problem. Did you fix yours, @Robinwchahal?
Similar problem in the .Net Atlassian SDK, in their own source code it tries to access
json[this._propertyName]where _propertyName is set to "name" and we get a NullReferenceException. Changing this to "displayName" makes my app work again.
I've asked my question here with a lot more details: https://community.atlassian.com/t5/Jira-questions/SDK-name-vs-displayName-userPicker-NullReferenceException-in/qaq-p/1303712
Same problem here, I guess an updated version of JRJC is required.
Simple call to project client fails. I don't need the actual value:
client.projectClient.getProject(projectName).claim()
