After making a field required for issue creation, the /jira create functionality in Slack has broken. It does not display the required field even though the docs for the Jira Cloud App claim that all fields will appear in the order that they appear in Jira. One possibility is the field is appearing under "More Fields" which recently became a think in Jira create issue dialogs. Perhaps the Slack app is not picking those up. Anyone else seeing this?
If you are willing to use another solution, the Actioner Jira Software app is suitable for those situations. The configuration can be done in its configuration screens and also you can alter the creation workflow any way you like.
Alper-
from Actioner team
Hey @Alper Saglam _actioner_ - Are you associated with this App as the vendor? If so, you must declare that in your name as well as any answers you provide for transparency.
Hey,
thank you for reminding me of that, I thought it was obvious since it is directly declared in my profile, etc.
I am changing my answer according to that and any future answers.
Alper-
from Actioner team
Thanks for doing that. You might want to update your actual username to include the Vendor name also - there are lots of examples out there in the Community.
