Jira Cloud Slack integration reports success adding a message to a ticket but seems to fail
Andrew Grossman
April 8, 2021 edited
I have the Jira Cloud integration enabled for Slack. I can click on the message actions and pick the "Add to issue (Jira Cloud)" option. I then pick the ticket to associate the message with and get the attached success dialog. But when I go to the ticket and refresh, there is no message attached.
David Michelson
April 13, 2021
Hi @Andrew Grossman
When you navigate to IM-30, make sure to look for "Slack > Open issue activity" on the right-hand side of the issue. This is where you can find any messages added to an issue from Slack.
Andrew Grossman
Thanks, @David Michelson Slack isn't listed in the issue fields for any project in our installation, as far as I've ever seen.
David Michelson
April 13, 2021
Ah strange, could you go to https://support.atlassian.com/ and create a support request detailing this issue? A support engineer will be able to look deeper into this as this should be appearing for you!
