×I'm reaching out regarding an issue I'm experiencing with the Jira Cloud for Excel add-in. Despite successfully signing in and selecting the correct site, I continue to receive the following error when attempting to run a JQL query:
"must set field 'siteId' in request"
I have already performed the following troubleshooting steps:
Despite all of this, the plugin still throws the same siteId error and does not load saved filters either.
Could you please help me resolve this or let me know if there’s a known issue or workaround?
Thank you for your support,
Hi Bharat,
This is Agam from cloud support team
The error message "Must set field 'siteId' in request." typically means that the siteId parameter is missing when using the Jira for Excel plugin to retrieve data from Jira Cloud.
This issue is often related to authentication and can usually be resolved by re-authenticating your Excel app with your Jira Cloud instance.
For the next steps, could you please:
Agam Gupta
