Sign up Log in
Jira DC / count members in multi select group
sylvain_lanthier2_bell_ca
I'm trying to update a "Number" custom field with the total count of members present in all selected groups within an issue.
Do you have any suggestions for how I can achieve this?
Regards!
Samuel Gatica _ServiceRocket_
August 19, 2024
Hi @sylvain_lanthier2_bell_ca
Unfortunately, Jira doesn’t directly provide a way to count users in a group via JQL.
As an alternative solution, you can achieve this by utilizing Automation and the "Lookup" action to retrieve group members.
  • Add a "Lookup" Action to Fetch Group Members: Add a "Lookup issues" action (this will allow you to perform additional logic). Use a JQL to retrieve issues that match your criteria, including the ones with the groups you're interested in.
  • Calculate the Total Count of Group Members: Use a smart value to calculate the total number of members across the selected groups.
    • {{issue.customfield_XXXX.size}}
  • Update the "Number" Custom Field: Add an "Edit Issue" action to update the "Number" custom field with the calculated count.
    • {{#=}} {{issue.customfield_XXXX.size}} {{/}}
Hope this helps!
Best regards
Sam
FREE
Register Now
Upcoming Jira Events
