Jira Dashboard Custom List - Show field next to Done ?
Raj Grewal January 28, 2025
Hope everyone is well.
I am trying to add the extra drop down next to Done into my Custom Charts Issue List.
However, I am unsure where this is and what the drop down would be called when trying to search for it.
Does anyone know where this would be located or called ?
Trying to show the points highlighted in red "Wont Fix" into another column next to our Done Column.
4 votes
Marc - Devoteam
January 28, 2025
Hi @Raj Grewal
Done is a status or status category in Jira. Won't Fix is a resolution used in Jira, use the field resolution in the chart.
This should provide you with the options from the field resolution.
Many Thanks
Like Marc - Devoteam likes this
