Jira HTTP bad request "Project is required"
Adwait September 19, 2016
Hi I am getting an error
HTTP Bad request 400
(  "Errormessages " : [], "errors":("project": "Project is required"))
my curl command=
curl -D- --user POST --data @C:\Adwait\AdwaitWorkspace\WS2\Login\jira\createJiraIssue.json -H "Authorization: Basic Yuuuuuu" -H "Content-Type: application/json" "http://xxxxx/rest/api/2/issue" -k -o C:\Adwait\AdwaitWorkspace\WS2\Login\jira\createJiraIssue-Output.json
my json=
"fields":
"project":
"key":"DevOps_Touch & Feel (DF)"
},"summary":"Performance test","description":"","environment":"","assignee":{"name":"A","emailAddress":"emailid_assignee"},"issuetype":{"name":"Bug"},"labels":["Automation"],"customfield_10222":[{"value":"Test1"}]}}
TõnisO
September 19, 2016
"project": {
That is definitely not the Project Key, looks more like the Name.
yes that is the name. What do i need to give as key?
TõnisO
September 19, 2016
Well.. the Project Key, obviously.
ASDDDD or REWR or RQW in the following example
harrison.fritz
March 3, 2020
The thing that fixed it for me was by adding the follwoing to the JSON. I needed both the key and id of the project. Once you do this it may ask you for some other "required" fields. The easiest way to find the values/id's/keys of these are to curl Get a specific issue and look through the returned json. https://stackoverflow.com/questions/50099499/using-jira-rest-api-how-can-i-get-description-of-a-specific-issue
"project":
"id": <YOUR PROJECT ID IN QUOTES>,
"key": <YOUR PROJECT KEY IN QUOTES"
Rachna Singh
February 14, 2017
Were you able to resolve it, Even after adding key , I am getting issue
JSONObject fields = new JSONObject();
JSONObject project = new JSONObject();
project.put("key", "1");
project.put("id", "intqm");
project.put("name","sample");
fields.put("project",project);
//fields.put("project", "1");
// fields.put("issuetype", new JSONObject().put("id", issuetypeid.toString()));
// fields.put("summary", "Test from JiraRestClient");
//fields.put("description", "Lorem ipsum...");
JSONObject issue = new JSONObject();
issue.put("fields", fields);
Register now
