Hi Team,
I am facing below issues in JIRA, could please help me in resolving these (Mars JIRA - https://marsaoh.atlassian.net/secure/RapidBoard.jspa?rapidView=126&projectKey=IFTACNDELV&selectedIssue=IFTACNDELV-747&sprint=456)
koteswara.
1. There is a checkbox in the time tracking web panel to include subtasks into the story estimate:
2. You would need to use a plugin to sum up all hours from sub-tasks and stories to the epic level. For example, you could have a look at the Structure plugin
3. What do you mean by downloading? Do you mean export issues to a csv file? Parent Id should not be empty. I just tried it in Cloud.
4. If you mean by downloading the csv file, for stories you should have a look at the Epic Link field. The Epic Name field is available only for Epics.
5. Hava a look at the reports option in the project menu. If you can not find a report, you need, then you can look for add-ons in the marketplace
