Jira Plugin: Custom field cannot show
Wenjing Liu July 22, 2025
I'm developing a jira plugin for custom field(test cmdb 2 ), however when I configure a Request Type and add it, it can only be Hidden fields with preset values and cannot show. I can't click the show button like below.
Thanks in advance.
Oleksii Melnyk
July 22, 2025
Hi @Wenjing Liu ! Did you specify the portal-view experience in the view entry point when using UI Kit for app rendering?
https://developer.atlassian.com/platform/forge/changelog/#CHANGE-2669
Wenjing Liu July 23, 2025
Hi, thanks for your answer, but I'm sorry that I 'm confused about your answer. Could you please explain it more clearly? Thanks very much.
I think I don't use the Kit UI, I just have two velocity files, the edit.vm and view.vm, so does this error due to these two files?
